Delete a multicast stream limitation member from an interface to remove it from the configuration.
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
  1. In the navigation pane, expand Configuration > IP.
  2. Select IGMP.
  3. Select the StreamLimit Members tab.
  4. Select the row that lists the member you want to delete.
  5. Select Delete.
